Jaguar rims
Old Feb 8, 2012 | 04:05 PM
uuuanut's Avatar
Default Jaguar rims
Will 2001 jaguar 16 inch rims fit a 1995 xj6? Which already has 16 inch factory rims.
THANKS
Old Feb 8, 2012 | 05:21 PM
motorcarman's Avatar
VDP wheels with 'hubcaps' will fit.
bob gauff
Old Feb 8, 2012 | 07:54 PM
cstu's Avatar
Another rim question for you, Bob...will XK8 17" Lamina rims work on a 97 XJR? I didn't have a problem with them on my 97 VDP but wanted to make sure.
Old Feb 8, 2012 | 09:37 PM
The main problem with the X300 style front hubs is that they have tapered roller bearing spindles and the X308/X100 have a press-in one piece bearing hub that is 'flatter'. The bearing cap on the end of the spindle sticks out too far and the hub diameter is different for the wheel center.
I don't have a cross reference chart to know what will fit what but I remember the X308 VDP wheels have that hub cap that will cover the extended spindle of the XJ40/X300 style front hubs. Some of the other X308/X100 wheels will not allow the wheel center cap to be installed with the spindle/bearing metal cap in place.
I have a brand new 17" Lamina wheel in a box and I have a 1992 XJ40 so someday I might try to fit the wheel to the car if I have it in the shop for some 'wheel-off' maintenance.
It was easier to try these thing when I worked at the dealer because we had so many different models/years in the shop at once. You could walk over to another guy and ask to borrow a customers wheel to try on a car on another lift.
I don't know if there is a comprehensive list of compatible wheels/cars!!
bob gauff
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
