Key cutting key tibbe stripped
its spinning on ignition help
_________________ 1996 XJ6 (added by GGG) |
If you are sure it is not the lock barrel itself spinning? Then your, probably, only choice will be to provide the VIN to the dealer and have them cut a new key. With that you can get cheaper duplicates from a locksmith.
Originally Posted by julandnic
(Post 1983567)
I've added vehicle details and moved your question from General Tech Help to X300 forum. This is the place to post questions about your model. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
You can follow instruction from this seller and get key code and cut.
https://www.ebay.com/itm/JAGUAR-DAIM...MaWU:rk:8:pf:0 https://www.ebay.com/itm/90-97-Jagua...bUs:rk:23:pf:0 |
