LCD repair
Hello all.
I recently purchased a 1996 xj6 VP. 400 mile trip and performed well. Serviced the engine oil, trans, rear diff and AC Now on to the radio and climate controls. All working but screens are jacked. No one in NM will touch it. Any suggestions? TIA |
LCD Clock = Module Master
https://modulemaster.com/rebuilds/sh...xjr-x300-1997/ LCD heater/AC = Probably Module Master, but honestly these rarely break, so a whole used unit on eBay may be a better deal. Module Master doesn't seem to have this as a standard item they rebuild, but they will usually repair just about anything and will likely offer a quote. Radio = Southern Electronics https://www.jaguarforums.com/forum/x...nt-turn-54075/ BTW, this only is relevant if the LCD itself is not working. If the lighting is simply out, you can replace the bulbs. Consult Jaguar Classic Parts for the correct bulbs, as they vary per module. |
