new strange thing happening today brake/shifter
1996 XJR .....LOL Jags - new thing going on today- I step on brake pedal and i hear a click in the gear shift knob
it even seems to move a little ? what is happening here ? every step on brake pedal - click on gear shifter- what am i in for now??
The following 2 users liked this post by b1mcp:
Jaglady96 (05-13-2018),
Lady Penelope (05-13-2018)
Here's a couple of threads that deal with the issue
https://www.jaguarforums.com/forum/x...-sound-142172/
https://www.jaguarforums.com/forum/x...-switch-85318/
Yes it's the small black switch. You will need something a bit like this
https://www.ebay.co.uk/itm/5-x-Lever...8AAOSwc3ZUpTZR
You will need to get the old switch out and check the dimensions to get a replacement as near the same as possible. There are lots of different shapes and sizes.
Check also whether the original is NO or NC (Normally Open/Closed) as I can't remember. I think probably NO.
Jaglady96 (05-14-2018)
There also is a dimension that the button on the switch itself must move before it actuates and " makes " . This is different then the metal arm that is between the target and the micro switch . Not easy to specify when purchasing but important in operation if it "makes " the switch .
An example would be the park switch inside the windshield wiper gearbox
Be very cafefull of the brittle plastic in the shifter box chrome surrounds
Lady Penelope (05-14-2018)
Jimbo Saunders
01-15-2018 10:09 PM
S-type_London
09-01-2011 07:23 AM
