Numptie's questions
On the white connector. Jag had trouble with the cooling fans failing when they were connected to a temperature switch that turned them on and off. The solution was to put a jumper in the system that turned the fans on when the ignition switch was turned on. If your fans come on with the ignition switch you have the jumper which is the best configuration. If they don't you don't have the jumper and need one. That white thing looks like that connector without the jumper.
