Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ6 / XJR6 ( X300 ) (https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/)
-   -   P1158 trouble (https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/p1158-trouble-213352/)
Boeingtravel95 01-28-2019 07:15 PM
P1158 trouble
Checked the computer and I pulled only a P1158 Code, problem is I need this fixed to pass NJ state inspection. Where would a good place to start with a problem like this? I've had the idle control valve replaced, 1 downstream O2 sensor, and mass airflow sensor changed within the past 2 years or so. Car also smells a bit rich. Any advice on where to start would be greatly appreciated!
Lady Penelope 01-28-2019 07:46 PM
For a 97 see page 124
ttp://www.jagrepair.com/images/Training%20Guides/801S%20-%202000.pdf
B2S2 , Lean Combustion
https://cimg0.ibsrv.net/gimg/www.jag...7b9ffb328d.png
Check for corrosion on the connector
The return to the ECU wire shield grounds on the rear firewall upper left and right ground post
Do a resistance ckeck of the heaters comparing 2 different sensors , wire Blue / Brown through White / Green on the sensor half of the connector
Clean the connector Papa Indy 61 pin 12 wire color White / Green
https://cimg1.ibsrv.net/gimg/www.jag...44d5d34ab8.jpg
https://cimg8.ibsrv.net/gimg/www.jag...d095103d67.jpg
https://cimg1.ibsrv.net/gimg/www.jag...b91ad3967c.png
Check condition of ECU connector socket Black 4
https://cimg7.ibsrv.net/gimg/www.jag...34acf858bd.png
Boeingtravel95 01-28-2019 09:55 PM
Thank you for all the info!! I noticed this is for high voltage p0158, I have code P1158 should I still go through this same procedure with this code?
Lady Penelope 01-28-2019 10:01 PM
Your right , I failed to read correctly
Do over
Boeingtravel95 01-29-2019 07:32 AM
Is it possible the catalyst is going bad?
Boeingtravel95 01-29-2019 04:14 PM
Is this the same for the P1158 running rich?
