Parking Brake Cable Removal?
Are you doing wheel bearings?
In the center of the diff cage, just below the driveshaft you should see the park brake cable. On the diff cage, there are 2 e-clips that secure the cable. Disconnect the park brake cable adjuster, then remove the e-clips and this will allow the cable to move if you need to swing the hub down.
Received 12,737 Likes
Hi 95Leaper,
If you'll let us know which of your Jaguars you're working on we can give you more specific replies and perhaps direct you to the appropriate Workshop Manual. The X300 and XJS are very similar or identical, but the XJ40 may differ a little.
Cheers,
Don
Cheers,
Don
Thanks for clarifying, 95Leaper. I've sometimes spent 30 minutes or more crafting a reply to a member who owned more than one Jag, only to find out that he had mistakenly posted in the forum for one of his other Jags, so I've learned not to assume anymore.
You can download the X300 Workshop Manual at one of the links below:
Jaguar X300 Workshop Manual zip
Jaguar X300 Workshop Manual rar
Cheers,
Don
Cheers,
Don
G’day 95,
There is a white plastic clip which secures the handbrake cable outer sheath to the rear brake backing plate and a small pin which secures the end of the cable to the handbrake
actuating lever.
Have a look here
https://www.jaguarclassicparts.com/a...d-caliper-rear
Cheers,
Jeff
actuating lever.
Have a look here
Cheers,
Jeff
If you have time, you would help others in the future if you could post some photos of the process.
Cheers,
Don
Jaguar brg
05-31-2016 02:03 PM
smoggyx100
08-05-2013 05:40 AM
smithrd6
07-31-2011 08:37 AM
