Part Number help for ECM
Can anyone tell me the correct part number for an ECM 1997 XJ6 with the VIN SAJHX6241VC794046 ? I just bought this car used and am having problems and suspect that the ECM in the car may have been replaced and not match the original. Any help is greatly appreciated.
Thanks |
There was a recall R493 and the related TSB 05.1-26am5 that had info about the new PROMS and ECM part number changes for the USA. There are 3 ECMs for 1997. SWB, LWB and Supercharged. If you're car is not US spec then I don't know. The part number is on the ECM paper label and a paper label was applied over the old one after the EPROMS for the recall were installed (if the car had the recall performed) 1997 SWB LNB 1410AE 1997 LWB LNB 1410FE 1997 XJR LNB 1410DD bob gauff |
Thanks Bob. The one I have is LHE2400AJ. Wonder if I have the wrong one.
