Part number(s) for exterior door handle gasket?
Tried looking through Jaguar Classics parts diagrams, to no avail.... searching here didn't turn anything up either.
Anyone know the part numbers for the exterior door handle gaskets? My drivers door exterior handle gasket is starting to crack.
Received 12,736 Likes
Hi Al,
I just took a look at jaguarclassicparts.com, jaguarmerriamparts.com, and in the Electronic Parts Catalog (EPC), and none of them show a gasket for the external handle available as a separate part. They do show a gasket for the inside door handle escutcheon. It might be worth giving Jaguar Merriam Parts a call to see if the guys there may be able to help (they're the Jag dealer in Merriam, KS who sell Jag parts online at discount prices).
If the gaskets are not available separately, you might be able to use an old gasket as a pattern and make your own new one from rubber sheet obtained from a local roofing, plumbing or HVAC supply, or online from McMaster-Carr. It comes in suitable thicknesses (1/32", 1/16", 1/8"). There are several grades. The non-marking neoprene might be a good choice.
I replaced the rubber flaps in a radiator cooling fan shroud with standard neoprene and it worked great. You just need to use a very sharp knife to get neat cuts.
Cheers,
Don
al_roethlisberger (04-05-2015)
These may be it:
Left hand: JLM12031GSK
Welsh Enterprises, Inc - Jaguar XK8 / XKR (97-06) Body Fittings Front Doors Parts - Left Door Handle Gasket
Right hand: JLM12032GSK
Welsh Enterprises, Inc - Jaguar XK8 / XKR (97-06) Body Fittings Front Doors Parts - Right Door Handle Gasket
Also, are the late 1990s XK8 exterior door handles the same as the X300? The links above seem to indicate they may be.
If so, I see the following:
Kit for left and right: JLM12035KIT
http://www.terrysjag.com/product/JLM12035KIT.html
New Left and Right Door Handle Gasket Kit for Jaguar 7837 | eBay
Don B (04-06-2015)
The following 2 users liked this post by Compounder:
al_roethlisberger (04-05-2015),
Don B (04-06-2015)
The following 2 users liked this post by GatorJoe:
al_roethlisberger (04-06-2015),
Don B (04-06-2015)
Scarecrow (04-13-2015)
There is this aftermarket option for $35 a pair that I have on my car. They're not the softest rubber out there but seem to do the job, and they fit the factory door handles with a minimum of stretching.
Door handle escutcheon gasket - P/N GMB 1152AA - Quantity 4
So it's identical gaskets used on the four doors. Same P/N is also used on the XJ40.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
innzane
09-02-2015 10:08 AM
