Pushnut Retainers
Pushnut Retainers
I'm replacing the center air conditioning vent and in order to remove it you have to remove the pushnut retainers that hold onto the plastic studs. Does anyone know where I can get the proper size replacements. I will need quite a few because I also plan on reconditioning the wood on another car. Below is a picture of a similar style retainer.
Received 12,732 Likes
Our local True Value Hardware store has the best hardware section in town and they carry those pushnuts in various sizes. They had the sizes I needed when I replaced the veneer on some of the trim in our '93. To press them on I used a small-diameter (6mm or 7mm) deep-well socket.
Cheers,
Don
Cheers,
Don
Cheers,
Don
That's what I figured. Why can't all these manufacturers either go SAE or Metric instead of a mix between the two. I know they get many parts from outside suppliers but it just makes things difficult for the people who have to work on these things. It would be nice to just go over to the tool box and grab my metric set of tools and have everything nearby rather than have to go back and forth ( and we've all had to do this) because some designer thought it would be a good idea to throw in a different style bolt,nut,or connector. Just food for thought....
Don B (04-09-2017)
Cheers,
Don
