Removing front shock
Since the front shock (damper) is not a strut but seperate from the spring is it difficult to remove. I feel I need to replace all the mounting rubber parts on the front shocks. The shocks themselves seem fine with good damping.
Any help in this are as always is greatly appreciated. |
You should check out this post with instructions and pictures
I hope this helps https://www.jaguarforums.com/forum/x...market-109819/ |
