Reset Check Eng light codes and P1177
Howdy Jag lovers!
Baby (97 XJ6 USA) just threw her first codes ( P1177 ). I just had a local parts store look them up for me, and I forgot to ask them to clear the codes. It sounds like this may be a potentially ignorable code, as I am not having any functional issues. Does anybody have experience with P1177 (no others were thrown)? Also, is there a simple way to reset the codes without doing the old disconnect battery trick? Perhaps a fuse, or a button, or a wire that could be grounded (or wire a reset button to)? |
1 Attachment(s)
DTC guide for you.
bob |
1 Attachment(s)
page 14/20 , Long Term Fuel Trim Too Rich - Banks 1 and 2 (FMFR) other sources words
Jaguar's words |
Hmmm. So I guess I need to check (blow out) the fuel return pipe, then look into the fuel pressure regulator. I doubt it is the MAFS.
I attempted to clear the codes but disconnecting the battery, and held the leads together for 30 seconds. Doesn't appear to have done anything, even my radio presets are still there. |
You need a code reader/resetting tool to turn the light off.
Probably the easiest thing to do is to revisit the shop or auto parts store to have them reset the light . Drive for a week and see if P1177 returns . Can't troubleshoot until you reset the fault flag . The LTFT is a learned setting that takes some miles and throttle up procedure to relearn the setting . It my be just a hiccup . By doing the Jaguar " Hard Reset " the ECU has to relearn the LTFT as well and the code is inhibited until the procedure is naturally satisfied in normal driving . This is a factor to consider in troubleshooting . External factors outside of the ESU that it can't adjust to is the other half . Since Fuel Pressure Regulators don't last forever and are cheap and easy to replace ( $ 65 ) and easily available locally it would not be a waste of resources . Fuel pressure after the FPR is 43 PSI at idle and bumps up to 46 - 47 on throttle up by the vacuum hose on the back of the FPR you can't see . Clogged return lines would keep it high . Some things are " Hard Reset " as you hold the cables overnight but then you know the danger of loosing the radio code .
Update: I got a code reader for myself and cleared the P1177 codes to turn off the dash light. "Baby" has thrown no fits for the last 1200 miles, so it was just a hiccup so far. I will do some Sea Foam next week for preventive maintenance. I am planning to use the brake vacuum line to suck up half of the sea foam directly to clean out the intake, then dump the rest in a half tank.
Originally Posted by XJ 4Ever
(Post 1773411)
I don't get the Seafoam thing at all.
It's not the 1950s anymore. |
Originally Posted by Ric in RVA
(Post 1773758)
Get a FP gauge and measure rail pressure directly.
Originally Posted by Mikey
(Post 1773773)
It's not the 1950s anymore. Like you, I'm naturally suspicious of all third-party fuel system cleaners, especially those added to the fuel tank, which are typically based on common solvents like mineral spirits and naptha and when used as directed are diluted to such a low concentration that any cleaning ability must be minimal. But some of the products that are injected into the air intake after the MAFS seem to have some demonstrable effect. Here's a video of what appears to be an unbiased test of the Seafoam intake cleaner that seems to demonstrate the removal of at least some carbon from the tops of pistons. I've used this product in a few cars and the treatment seemed to help, most notably in a Mini with direct injection and heavily-carboned valves: Also, some automakers recommend the use of certain fuel injector cleaners that are forced directly into the fuel rail. General Motors instructs its dealership service departments to use the product shown below when a vehicle exhibits certain symptoms. A special canister is required, in which the cleaner is mixed with a small amount of gasoline and forced into the fuel rail under pressure. https://cimg3.ibsrv.net/gimg/www.jag...3223af0b35.jpg Cheers, Don |
1 Attachment(s)
TSB 303-67
Jaguar Cars recognizes that there are many types of commercially available pressurized injector cleaning kits as well as cleaners to choose from. You may use any existing equipment you have provided you are able to obtain satisfactory results. However, if you need to purchase this equipment, Jaguar Cars recommends the Ford Motorcraft Pressurized Injector Cleaning Kit and Motorcraft pressurized injector cleaner. This equipment has been fully tested by Jaguar engineering and has been found to perform to Jaguar Specifications. The Motorcraft Injector Cleaning kit, CM-1000 and cleaner, CM-1001 can be obtained through Excelda Manufacturing, (248) 486-3800 ext. 114 Kristi Mitchell. Note: Please have a Credit Card available when ordering Additionally the Wynn’s brand Injector cleaning kit and cleaner are also recommended, and can be obtained from a local distributor. To locate a distributor call (800) 989-8363 or visit Wynn's USA | Wynn's Preventative Maintenance Products & Services. |
Originally Posted by Don B
(Post 1773856)
Thanks, I've seen that video before. The problem is that the mount of carbon in the before pictures is pretty insignificant and well below the threshold of affecting performance, fuel consumption or engine durability. The tiny amount of contamination that was removed will soon return, so the time and money spent on the treatment was wasted.
(Post 1773856)
Also, some automakers recommend the use of certain fuel injector cleaners that are forced directly into the fuel rail. General Motors instructs its dealership service departments to use the product shown below when a vehicle exhibits certain symptoms. A special canister is required, in which the cleaner is mixed with a small amount of gasoline and forced into the fuel rail under pressure. The OP's car, like 99% of the cases that appear here, do not match the basic symptoms. My view of Seafoam (50% petroleum oil, 25% naphtha and 25% rubbing alcohol) remain unchanged. :icon_toast: |
