Right side power windows not functioning
Had this issue since i bought the car but didnt managed to figure it out.
On the right side of a car both power windows of both doors do not work. They do not work on both doors localy and dont work from a master controler in left drivers door. Anybody has a clue where start to look for ? Thanks. |
Left windows fuse # 15 / 30 amp green LH Heelboard fuse box
Right windows fuse # 15 / 30 amp green RH Heelboard fuse box Logic relays inside door's switchpack Gets a ground through the ignition switch for all windows |
Originally Posted by RB_jaguar
(Post 1811752)
Lasted long time till i started solving this problem.
I checked the RH heelboard fuses and found that the 15th fuse was missing. Mounted the new one in and to my disappointment i have only a rear window that started working. The front right window still doesn't work. When i push the window button i hear a relay clicking, but window is dead. Am i having a dead motor issue or is there anything I can check before searching for a spare motor? Thanks guys |
https://cimg5.ibsrv.net/gimg/www.jag...11316a971.jpeg https://cimg7.ibsrv.net/gimg/www.jag...fa560d101.jpeg https://cimg8.ibsrv.net/gimg/www.jag...db66b1716.jpeg https://cimg0.ibsrv.net/gimg/www.jag...3298f5ada.jpeg https://cimg2.ibsrv.net/gimg/www.jag...0ca5bfb95.jpeg https://cimg9.ibsrv.net/gimg/www.jag...45b16cf3f.jpeg https://cimg1.ibsrv.net/gimg/www.jag...eabcbe3c4.jpeg https://cimg3.ibsrv.net/gimg/www.jag...d80d4fb56.jpeg https://cimg4.ibsrv.net/gimg/www.jag...b2adacf02.jpeg If the clicking you hear is in the master switch then it might be that the relay contacts are dirty. I had this on my car. the contacts would pass voltage but NOT current I removed the master switch and stripped and cleaned the contacts. Then repeat on the inoperative door. Do not be fooled if the relay ohms out as working! |
Today started messing with this window.
Disassembled the door panel, all the buttons and connectors. Checked the motor supplying the direct 12 to the motor. No result- motor does nothing. Measured the resistance with the tester but it shoes no continuity. As if its burned. Also measured the voltage from the button to motor connector - while not pressing somewhy there is always 12v, when pressing the button down ( relay clicks) voltage goes to 0V Anyone has a clue, why when pressing button to open the window, voltage drops to 0? or this is normal operation condition. Window is closed and when i press the button up there is no clicking, only clicks when pressed down. Maybe someone knows how it should be operating, because know i suspect that failed switch burned the motor supplying in off position the current. Mahttps://cimg2.ibsrv.net/gimg/www.jag...70ad4e0d03.jpg |
No movement when power direct on the motor shows that the first thing you need to do is find a replacement. I have second hand motors from my XJ40 but not sure if they are the same as the X300 and I am on the other side of the world so probably of no practical use. |
What do you think about the voltage in the connector?
Now I have a theory that if I have 12 volts with no pressing the window button, that means motor has a current and load. Can it be that this constant current burned the motor. My logic tells me that I shouldn't get voltage with no pressing the button. Maybe the switch button is defected and burned the motor. What if I replace it and it burns again? I think there could be a window close relay stuck, that caused the motor to burn. I wonder are those relays repairable or replaceable or its just isn't wort to do that, simply replace the switch itself is probably simplest solution. |
What I found on mine was the locking bar holding the sockets in place was loose , this allowed a socket to migrate and loose contact . Since you have 2 windows acting up I would look at the driver / master position .
In a pinch you can use a battery charger to drive the motor up or down . Just swap polarity on the 2 motor wires . lt's a high current so arcing hazard . |
The problem was a burned motor and a stuck window close relay.
It appears that the stuck button relay burned the motor. Solution - changed the window motor assembly and the switch mechanism. Also put the new speakers inside. Job done. |
