She’s home
She’s home
We picked up the car today and drove the car back 140 miles. All went well.
When I got the car back I have it a wash and a look over.
Fixed the cup holder, it’s closed now.
Polished off all the **** scratches.
Car looks fabulous.
Intwrsing issue. When the doors are open in the eve and it’s dark, the interior lights flicker at a very high pace along with a relay that makes them run. Once you close the door it goes way. Any other car has the light lights in when the doors are open.
Wjay could be ?
And throttle pedal is still stiff. Do I have to take the throttle body off to give it a cleaning ?
Thanks.
Car looks fabulous.
Wjay could be ?
Thanks.
So far fixed the cup holder. It closes for now.
Polished out all the small scratches. Cleaned the interior.
Fixed the sagging headliner as much as I could with small pins. Sad was not bad enough to warrant headliner removal.
Gonna try to clean the throttle body this weekend.
Mane will try to trouble shoot the steering tilt mechanism. If I could get it down with 12v from the battery, that would be great. If not, I’ll order a used motor from eBay.
See TSB for part #
Don't pry to hard on the plastic sensor mounting clips
http://www.jagrepair.com/images/TSB/...r%20Seized.pdf
Do not remove the TPS and IAV from the TB barrel casting at this time
JessN16
22
08-12-2010 08:07 AM
