Sourcing a Mass Airflow sensor
As I am encountering problems with my MAF(AFM), was wondering if there are any go to manufacturers for our sensors? Any to stay away from?
I am receiving a loaner soon to make sure it is the sensor and not a wiring problem. Will be checking power and ground to it, as well as checking the signal output voltage tomorrow. Just wanted to start shopping around soon and being our sensors aren't cheap I want to purchase one that will last. |
Scarecrow:
I have had mixed results with "offbrand" MAF sensors for my Jags and Rover. I will always pay the exorbitant OEM brand price in the future. |
That's what I was afraid of. I found a used one on eBay "tested and in working condition" for $60. It's being shipped now. Will send the loaner back to its owner when it comes.
Had a chance to test it this morning when I got to work. Getting battery voltage and ground to it. But the signal is sending .09v at whatever range, idle to WOT. No where even close to a volt at idle. Don't really need the loaner now. That AFM is fried. The car only has 53,500 miles, but the sensor is not original, it's a fuel injection Corp. aftermarket. The guy I bought it from had a few xj6's and I'm pretty sure he switched it out between cars. Are the genuine sensors a problem child for this vehicle or are they pretty reliable? |
Chris,
I assume your OE MAFS is the Lucas LHE 1620 AA if you have the Lucas-Sagem-GEMS Engine Management System (EMS). If so, I don't know of any source other than Jaguar for an OEM unit, and both jaguarclassicparts.com and jaguarmerriamparts.com show that part as discontinued and no longer available (and when last available the "discounted" price was $1,315.03!!!) RockAuto and Parts Geek are both out of stock on all of their aftermarket options. I just checked everydayxj and growlerparts and no luck there. This U.K. company claims to have a new (probably aftermarket) unit in stock: Jaguar X300, XJ6, XJ8, XJS Air Flow Meter LHE1620AA | World Car Parts > Store And this company claims to be able to repair the Lucas LHE 1620 AA MAFS: Lucas LHE 1620 AA As long as working used units are available on eBay for $60 they may be the best option. Please let us know how it works out. Cheers, Don |
Would you trust a used one?
Originally Posted by mgb4tim
(Post 1369481)
Well, the MAFS in most running X300s are used.... :) In the absence of a reliable source for an affordable new one, a working used one may be the only option. Unfortunately, that is increasingly becoming the state of things for many XJ40/X300/X308 parts. |
Originally Posted by Don B
(Post 1369498)
Looking at the prices of oem sensors makes me cringe. $1400 for a maf is beyond insane. That's a third of what I paid for the car. That being said, I love my car and if push comes to shove I'll try and find the part and pay the price.
(Post 1369481)
(Post 1369407)
Update: I jumped in my car today after work to go home. Nothing but stalling unless I keep my foot on the gas, which also sounds like a idle control valve problem. I'm 100% sure my maf is bad. Hopefully that's the only thing wrong with it. Guess I'll have to wait to put in the replacement to find out. Maybe cleaning the IACV won't hurt either.
The car was running pretty bad for about a week before it finally threw the P0102 code. I cleared it, and even now, the code has yet to reappear. I know our cars are hesitant to throw misfire codes, is that true with other types of codes? |
I purchased one of these Air Flow meters (LNA-1620AA) from World car Parts Dec. 2014. Cost with postage here to Australia from the UK was AUD$238, very reasonable I thought & happy with product & service.
Whilst unbranded it appears to be new. Are you sure that is your problem, I would attempt to narrow it down as much as possible. John Herbert |
Originally Posted by John Herbert
(Post 1369705)
Whilst unbranded it appears to be new. Are you sure that is your problem, I would attempt to narrow it down as much as possible. John Herbert I am getting battery voltage and ground to the inner and outer wire (the colors escape me atm but if I remember power was the wire in the connecter closest to the radiator and ground closest to the firewall). And was getting only .09volts out of the middle wire which is the signal output to the computer. |
If it's any comfort I just bought a used one in the UK 11 pounds delivered (too cheap to ignore they are usually at least 30 pounds) and it worked fine and tested fine. But it sounds like you want new.
Isn't the MAF output reported very low by the Jaguar OBD or am I getting this muddled with something else? |
Originally Posted by drmike
(Post 1369726)
Isn't the MAF output reported very low by the Jaguar OBD or am I getting this muddled with something else? Attached is a chart of voltage vs. Kg/s of air https://cimg0.ibsrv.net/gimg/www.jag...f2ba271f71.gif |
Update: I received the used MAF and installed it about an hour ago. Was able too start up and drive the car home with no problems. The car runs way better but I think there is still a little roughness in it. I'm probably just imagining it though. I know it was running pretty rich and the exhaust smelled pretty bad of unburnt fuel. As well as blowing out some black smoke when we tried to get it started yesterday. The spark plugs may be fouled from the excess fuel that's been running through it. I have an extra set of 6 laying in my garage. When I get back in town, I will be tackling my spark plug seals and valve cover gasket. I will check the spark plugs then.
The exhaust does smell better now with the working MAF and no sign of smoke. Also my ultragauge is reporting a much much better short and long term fuel trim. Here are pictures of the before and after fuel trims reported by the ultra gauge. https://cimg7.ibsrv.net/gimg/www.jag...b1ce82238e.jpg Before https://cimg8.ibsrv.net/gimg/www.jag...99f1afcfc3.jpg After:<br/><br/>(I got lucky with the short term at zero during the shot, it was trimming between positive and negative) I found the website for the seller John Herbert was referring to. Will most likely be ordering one soon. Link attached just for future reference. http://www.worldcarparts.co.uk/Store...1/Default.aspx |
(Post 1369407)
Chris,
I just checked everydayxj and growlerparts and no luck there. Cheers, Don Don, Thank you for the mention.... I have a lot of parts on hand that haven't made it to my site yet. I always encourage people to email for availability. I have a couple of used MAF sensors for the X300 on hand for less than the $60 ebay price. It sounds like the issue may be sorted now.... Cheers David shop.everydayxj.com |
As soon as the cold weather hit here in upstate NY my 2000 xj8 started having problems starting for the first time each day in the morning. It would fire immediately but would not idle high enough to stay running. Engine has never had any starting issues for the 140,000 miles I have put on it over the past 7 years. I installed a MAS that was new, $20 from ebay. Car starts immediately now but does not run quite right -lacks power. MAS air intake temperature reads -40f. Since I know changing the sensor fixed the starting problems I am going to source another brand on ebay. This one is $40. If this doesn't work, then I am going with a new Desno OEM that I found on line for $130
What maintenance can be done to prolong the life of these sensors? I don't like the idea of sending these great cars to the compactor just because one sensor is no longer available.
EZDriver - I have been told that you can clean them with an electronics spray cleaner. I have not had any success with this though. But no worries, I bought a MAS for $100 that worked fine for 5 years. I just replaced it with one that was $40 and the car is working great. I did buy one for $20 that was defective and returned it. If I have further problems I will purchase the OEM Denso unit for $130.
Steve |
Originally Posted by taylormobile
(Post 1402308)
Steve |
I didn't even find a denso unit for our car when I was looking. Still can't find it. Can you post a link? Would be interested.
Chris Sorry it took me so long to post this. I could not find the site. Pretty sure this link is what I found for the OE Denso MAS, but it is $150 not $130. Website is Partsgeek.com
00 2000 Jaguar XJ8 Air Mass Sensor - Air Intake - A1 Cardone, Denso, Pierburg, Spectra Premium - PartsGeek |
