Squeak Sound, HELP!!
I own a Jaguar XJ6 1995 and it always has a LOUD squeaky sound, Ive replaced both belts and the only time it stops squeaking is when I put on belt conditioner but then in around 10-15 mins it starts squeaking again LOUDY. Any Fixes?
check your crank damper for delamination; a/c idler pulley may be shot.
The whole A/C Compressor part is brand new, just replaced it
Originally Posted by Jorge Dias
(Post 1539192)
It's your harmonic balancer more than likely. Make a mark across the pulley with chalk, start the car with all body parts clear of the engine. Shut the car off and check the line . If it's no longer connected as you made it the balancer needs to be rebuilt.
