stock fuel pump lph
Old Oct 4, 2013 | 12:31 AM
avioni's Avatar
Default stock fuel pump lph
anyone knows the stock fuel pump LPH rate on the normally aspirated x300? would a walbro 255lph be more than the stock?
Old Oct 4, 2013 | 11:05 AM
XJR-99's Avatar
XJ8 has one 155lph / 3bar Denso pump and X308 XJR has two pumps.
I guess X300 has not higher capacity pump, so Walbro would be well enough for your needs. Single Walbro 255 high pressure pump supports 500+BHP with stock pressure. I have two of them in my car. Please check your return line, since you may see too high fuel pressures with Walbro if you do not increase capacity of the return line.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
