Strange noise from Rear
Hi there, first thread.
Started up my 97 X300 (XJ 4.0 Sport) and sat there for a few seconds while I worked out how many failed bulbs there are in the heater panel and clock. A few seconds later while still idling in Park there was a mechanical noise from behind me which I can only describe as "Roarp". Lasted half a second and stopped. Went to the local supermarket and back and the car is fine. I don't want to create problems where none exist but do failing fuel pumps make noises on startup ? Or is there anything else at the rear that could make a mechanical noise while stationary. Ta. |
No, the fuel pump wont make noise. Sounds like the antenna motor. Does it go all the way up, and all the way down properly?
Originally Posted by rod_f
(Post 1002906)
Hi Rod, Welcome to the forum. Please be sure to post an intro in the New Member's Section when you get a chance. The noise you heard in the rear end could certainly be related to the fuel pump. Another possibility could be the electrically-operated radio antenna/aerial, which extends after startup if the radio is on. Perhaps the mast is dirty, corroded or slightly bent and is sticking as it reaches its full extension. I can't think of anything else back there that moves until the transmission is moved into a forward or reverse gear. Perhaps other members will chime in. Cheers, Don |
Could be your fuel pump getting tired, another possibility is a seized up power aerial, they do make some horrendous groans when they've not seen lube in a while!!!
Radio Aerial, good call, a lot cheaper and easier.
I'll check it tomorrow. |
I did change the aerial as one of the sections was sticking. Getting the sleeve out was proving difficult so I followed step 3 on the link and it worked a treat:
www.AntennaMastsRus.com |
(Post 1032170)
Hi Rod, Is the noise gone now that you've replaced the aerial? Cheers, Don |
Hi Don,
The alarming noise was a one-off event but in general the aerial struggled to rise and fall smoothly. It was old and I think some of the sections weren't quite fully straight anymore. Anyway it seems happier now and I'll wait to see if the noise ever occurs again. Rod |
