Tel-Mute function
I have a base model X300 3.2 model 1994/5 with its base radio. I know that on a fancier radio fitted to the XJR 4.0 model there is a sequence of buttons that turns off the Tel-Mute function. Is there a way of doing this for the radio I have?
I am plagued with the common problem that Tel-Mute is on 80% of the time despite having no phone and having disconnected the phone module in the boot. I'm not optimistic that it will fix the problem anyway but I'll try it. I found one link suggesting it's dry joints in the PCB in the radio that causes this and other problems. But rather than going down that route I'd try a simpler method first. Many thanks Mike |
Originally Posted by drmike
(Post 1386285)
I am plagued with the common problem that Tel-Mute is on 80% of the time despite having no phone and having disconnected the phone module in the boot. I'm not optimistic that it will fix the problem anyway but I'll try it. I found one link suggesting it's dry joints in the PCB in the radio that causes this and other problems. But rather than going down that route I'd try a simpler method first. |
I saw that post and I did wonder if it was available to me but I suspected not. I may drop in to the local dealer and ask but I am not holding my breath :)
Radio Setup:
Press TAPE IN and FM/AM at the same time Press within 15 secs one of the following buttons: 1 SEEK/SCAN function: USA / Australia 2 Tape head cleaning service reminder: on / off 3 Aerial cleaning service reminder: on / off 4 Telephone mute function: on / off 5 RDS: normal / mute |
Thank you and I will try it Now!
Drat I just tried it but as the radio was displaying Tel-Mute at the time I don't think it was capable of displaying anything else and responding to this action. I'll have to wait until the radio drops the Tel-Mute and try then.
Well I got to turn the Tel-Mute off as the radio did start working for a while yesterday. Will it work again today? The tension mounts :)
One step forward, one step back.
I managed to turn off the Tel function so Tel-Mute no longer appears which is great. But the antennae no longer goes up when the radio is switched on, it has a life of its own and yes Ant in ON in the settings. It went up and down a few times and after 20 minutes decided it would stay up which was nice. I suspect it may not get it up in the morning though. (And the Jag stalled for a second time while idling at lights - damn). |
