Timing chain cover slot versus no slot
Old 05-06-2019, 11:15 PM
Default Timing chain cover slot versus no slot
I have two X300 cars disassembled in my shop and the 1995 car is the one where the previous owner had disassembled the front of the engine to remove the timing chain cover.
On this engine there is a slot in the cover where the shaft for the intermediate timing chain gear protrudes through the front of the cover. There is a sheet metal plate that is held on with three bolts that normally covers up this machined hole. Inside the hole is a bushing that supports the front of the shaft for the intermediate timing gear. I cannot figure out why this slot on the bottom edge of the hole is there as it seems like it would lead to a oil leak.
The other car is a 1997 XJ6 and I pulled the plate that covers this hole so I could see if this car had the same slot and it did not.
This slot has square edges that makes it look like it is machined rather than some random broken off piece.
See the photos below that shows what I am talking about. The first two photos show the 1995 engine that has the slot and the last photo shows the 1997 engine that does not have the slot.
See machined slot at lower edge of the ridge around the hole.
Closeup of the same edge showing the machined slot.
same hole edge on the 1997 car with no slot
Old 05-06-2019, 11:17 PM
CRAP, I put this in the WRONG forum group.
If the moderator sees this, can it be moved to the X300 forum?
Old 05-07-2019, 08:48 AM
Received 7,689 Likes on 4,287 Posts
Hi Steve,
I moved the thread for you.
If I recall correctly, it is the intermediate shaft oil seal that should prevent leaks. The cover plate is just a flat triangular metal piece and doesn't actually keep oil in, it just helps keep debris off the ends of the bushing, seal and shaft. I don't see a corresponding slot machined below the auxiliary shaft cover plate mount. Very curious. Could the slot be used for locking the intermediate shaft in position?
Cheers,
Don
Old 05-07-2019, 11:06 AM
I have had two of these apart now and I do not see any oil seal on the front end of this shaft.
There is a bushing in the front timing cover but no oil seal. In fact the triangular plate on the one motor that I removed last night was sealed with silicone.
Old 05-07-2019, 12:26 PM
Hmmm.... in the diagram below, part 8 is the intermediate shaft oil seal:
You can check part identifications and numbers here:
https://www.jaguarclassicparts.com/u...-3-2-4-0-litre
In your photo, the ring marked DOWTY is the oil seal. The U.K.-based Dowty Group was a long-time seal OEM to Jaguar.
Cheers,
Don
Zhangsta
06-08-2017 09:14 PM
slanham
General Tech Help
02-01-2014 06:34 PM
slanham
General Tech Help
02-01-2014 03:20 PM
Burra
02-19-2013 06:31 AM
Quick Reply: Timing chain cover slot versus no slot
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
