Transmission dip stick.
Guys. After reading the manual, it looks like I’m not missing anything. But I can’t get the dipstick out. I unlock it by pulling it up and try to pull. But it won’t come out. I’m afraid of breaking it. Is thwre a trick ? 96 xj6 |
It is a common fault.
I usually end up spraying penetrating oil into the area on top of the steel tube and then twirling/twisting/pulling until free. bob |
Oh thank you. Never thkight that cohld could be an issue. I simply wanted to check the fluid and was afraid to brake the dipstick making it useless and stuck. |
