Trunk water leak
Trunk water leak
Hi.
I have a small water leak in the trunk. I can see the water trickling down the rear wheel arch inside the trunk, but can not find the source of the leak. I sealed the body seam that runs from the rear window to the trunk opening but it still leaks. I also run some window sealant around the corner of the window. Has anyone had the same problem, and cured the leak. Could the rear quarter light window be the cause and the water is tracking along the inside and ending up in the trunk?
Timothy
05-16-2012 07:14 PM
newuser
04-17-2010 11:35 AM
