Washer Resevoir
Old 01-13-2019, 06:56 AM
97XJR-Flausa's Avatar
Default Washer Resevoir
My plastic washer resevoir is toast on my 97 XJR and I removed it from the vehicle. Whilst I try and find a reasonably priced replacement does anyone know the easiest way to eliminate the light on the dash that tells me I am low on fluid?
Old 01-13-2019, 07:11 AM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
The fluid level switch is the Orange / Red wire to Black car frame ground
With the connector removed and you get the light would mean putting a jumper wire in the connector would put it out
When I got M'Lady P the res was missing but you have one to compare on a X308 from 1998 to 2006 at the salvage yard
I know the filler neck cap is different but may work , you would have to verify the connectors are the same
If you are crafty a large powder protein mix bottle ( 5 LB size ) from the gym fits perfect
Note : there is a resistor built into the switch uf unknown value so the jumper wire need a resistor to not short out the instument cluster device it's wired to
Her jag
01-02-2015 09:06 AM
stevemilleresq
01-17-2012 10:52 AM
stanstinn
09-17-2011 09:34 AM
yjmcb
09-30-2009 02:56 PM
Big E
XJ40 ( XJ81 )
05-28-2009 11:14 AM
Quick Reply: Washer Resevoir
