What a difference a new timing chain makes
Old Mar 22, 2010 | 06:50 AM
Default What a difference a new timing chain makes
Finally got sick of the rattles in the 3.2ltr X300.
This may of interest to some.
Replaced the top tentioner (updated version), with another updated version, not much change, mmmm.
Peering into the depths of the timing cover, with the cam cover off, I noticed that the chain still had slack, not good.
Had a spare new chain here, for something or other, cut it at 43 links, found a joiner link, wound in the new chain, reset the cam timing, it was out before I started, so someone has been here before, refitted the tentioner, fired it off, camcover back on, started the beast, SILENT, sweet, consume beer, MANY.
At 154000kms, this should not be an issue, but I reckon that poor servicing (despite the books), and cheap oil have contributed to this chain wear. I know that the blades and dampers are probably just as sad, but when the engine comes out, and it will one day, they will be attended to.
So for now the mighty XJ-S is back in storage, and the 3.2 is the daily driver again.
Old Mar 22, 2010 | 07:07 PM
jhxj6's Avatar
Has anyone seen improvements from buying the new tensioner chain? Mine too rattles a bit on crank.
________
CLASSACTION SETTLEMENTS
Old Mar 23, 2010 | 10:11 AM
MTZGR777's Avatar
Yea me too. It makes an annoying rattle on warm start ups.
Old Mar 23, 2010 | 02:14 PM
panchostatus's Avatar
usually just changing out the tensioner fixes things
Old Mar 23, 2010 | 03:59 PM
MTZGR777's Avatar
Is that hard to do yourself? And how much do those usually go for?
Old Mar 23, 2010 | 04:54 PM
It's not hard to do yourself at all if you know your way around under the hood, the TSB gives you step by step instructions, and I actually have no idea how much they go for. I've seen them on ebay for 25 or so but I don't trust it.
xjrjag
May 21, 2026 09:05 PM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
souldoubt
Aug 25, 2015 08:15 PM
