I would suggest
Cabin air vents (usually for broken vane clips)
ABS Sensors
Key Fobs for both frequencies
Catalytic Converters (CARB compliant for mine)
Sunroof assembly or parts would be useful
Power Steering Pump
TPS Sensor
Its the Jaguar Enthusiasts' Club https://jec.org.uk/ They are working with SNG Barratt to work out what they need to make, they have already introduced many items but what to know what is needed the most..
Center console Edge finisher, the rubber interface trim between ashtray and skijump.
Gearshift aperture finisher and Gearshift surround (with tabs that won't break!).
Waist Seals (door to glass). Any remaining stock going for ridiculous prices, particularly for my black XJR 100 seals which can be priced at over $900 each!
Here's my starter:-
Rear ABS sensors (they're only currently available for the very late x300s from VIN 801672 ) LNA2222ABLNA2223AB
Waist seals with black finish, front now unavailable - GNA1710BFGNA1711BF Rear still available but crazy prices - GNA2520BFGNA2521BF
Accelerator pedal pad CCC6762
Intermediate handbrake cable MNA5169AB
Centre Console Switch panel moulding (These are getting very brittle with age and the screw lugs break off) LNA6318AA/BA/CA/DA
XJR6 MAF LNA1620AA
XJR6 Throttle cable (Traction Control Actuator to Throttle Body section) for RHD vehicles. MNA4620LE
XJR6 Supercharger bypass actuator (These are starting to fail) NBD7703AA>NBD7703AB
Exhaust manifolds are still available from Aston Martin, the 1995-97 DB7 I6 uses the same manifolds. They are the same as X300 with EGR and Air Injection, these can be plugged for use on a car without it. Not cheap but could be worse!
Thanks Cafcpete for starting this thread.
Greta list everyone. It is becoming increasingly difficult to get parts for X300. I'm sure a number of cars are no no longer on the road for lack of parts.
For anyone needing to do a major engine rebuild, pistons will need to go on the list of part that it would be helpful for SNG Barratt to re-manufacture.
