Where can i find the Diagnostics Port on LHD 1996 XJR
Hi guyz, my car is not starting up and i want to do Diagnostics so where can i find the Diagnostics Port on LHD 1996 XJR and what type of Diagnostics connector does it have?
Many Thanks ! |
The OBDII port is roughly where the upward sweep of the center console intersects with the lower edge of the dashboard.
Cheers DD |
Many Thanks Doug !
Is there any chance that i will get the Failure code for any sensor when there is no check engine light on? I bumped into a big hole with my car and the engine started working bad + the black smoke from the muffler. I hope that there's something with the hose or any sensor that i can connect back because there is no way i can rebuild/fix the engine here in Georgia. P.S. Now the car won't start at all. I mean it starts if you push the gas pedal till the end and the engine works really bad + the black smoke + there is a smell of gasoline somehow. |
