Wiper motor arm position relative to spline of motor
I had to swop over a wiper mechanism from another motor. I took note of its position on the old motor but it must not have been in the rest / off position when removed. When installed, using the same positioning mark, the wiper comes to rest on the passenger side when it parks, so the position is some degrees out.
Does anyone have a photo showing this crank arm at the "home" or "off" / "rest" position relative to the motor spline, or perhaps an easy way of getting the timing right? Anyone have a photo showing this crank arm at the "home" or "off" / "rest" position on the motor? Or perhaps an easy way of getting the timing right? Cheers |
You can take the bottom of styrofoam cup and spear on to the final shaft marking the park position
