Wiper Motor removal
SO I looked through the posts and found one that kind of explains it. So I remove the top bolts on the cover and then I guess there are three slides at the bottom and once you move those then it will come out?
https://cimg1.ibsrv.net/gimg/www.jag...e7f6680231.gif
I had too much fruitcake for Christmas Before you remove it there is 2 relays and such Fuse # 6 / 20 amp LH engine fuse box and # 16 / 10 amp RH Jeelboard fuse box You can always jumper wire across one relay socket ad watch it run Others have had issues with the column switch wiring , the park switch , and the shaft bolt coming loose on the inside of that large black cover You can put some heavy grease on the swivel pivots on the short articulating arms I already have a a crayon drawn out picture on my mom's refrigerator she is proud of , she didn't think I would amount to anything https://cimg2.ibsrv.net/gimg/www.jag...8090fcaff3.png https://cimg9.ibsrv.net/gimg/www.jag...099a966946.png Keep track of your parts " stack " To remove the bottom clips put some penetrating spray or bearing grease in the clips with a heat source ( lighter ) to melt the grease and wick into the area of interest With a metal coat hanger make a hook that can go into the clips Make a second hooked coat hanger to pull the first one in place pulling from the left side The other end from the hooked end clamp a vice grip so you have a sling hammer type tool to pop the clips over 1/4 inch only , they pull to the right side |
