Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ6 / XJR6 ( X300 ) (https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/)
-   -   xj6- where does the vent hose from the oil dipstick go to? (https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/xj6-where-does-vent-hose-oil-dipstick-go-102009/)
JC in VA Sep 5, 2013 12:00 PM
'96 XJ6- There's a rotted broken rubber hose connected to the oil dipstick tube. I want to replace it, but I can't find where its supposed to connect to on the other end. I assume it eventually connects to the air intake stream, similar to the old PCV (crankcase breather valve setups).
Anybody know where it connects to ? Thanks
GGG Sep 5, 2013 01:15 PM
2 Attachment(s)
Welcome to the forum JC in VA,
I see it's a while since you signed up. Hopefully been trouble free since then.
I can't recall a rubber hose on the dipstick tube of my X300 other than the the Tube Sleeve (item 15) connecting it to the Oil Sump Location Tube (item 8):
Attachment 53463
Members who have this model now might have better information than my memory of previous models I've owned!
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
aholbro1 Sep 5, 2013 06:35 PM
4 Attachment(s)
No hoses attached to my dipstick:
https://www.jaguarforums.com/forum/a...1&d=1378423957
https://www.jaguarforums.com/forum/a...2&d=1378423972
SleekJag12 Sep 5, 2013 07:23 PM
At some point for the 1996 model year, the breather hose oil return, via the dipstick, was deleted. My earlier 96 has it, the later 96 doesn't! The hose goes from the dipstick tube up to a plastic connector attached to the crankcase breather hose. The larger hose to the intake elbow also connects to that plastic connector.
I believe the idea was to prevent so much oil from being sucked into the intake. I don't know why it went away. I can say that there is a lot of oil in the intake elbow of the later 96 that doesn't have the drain!
Of course the rubber hose will disintegrate after a few years, as it gets saturated. I used a length of 3/8" hose to replace it just last month.
JC in VA Sep 9, 2013 04:08 PM
Thanks Richard. That's it! I can see what's left of the hose on the underside of the black plastic container. I assume that's an oil/air separator. Thanks again.
John
JC in VA Sep 9, 2013 04:21 PM
Thanks Graham. I'll post info on the New Mewmber section. BTW, where did you find the parts list and diagram? I've got a factory manual on CD. Some areas are poorly covered or not at all. No info on crankcase venting for example. I'm always looking for a good shop manual.
Thanks again. John
GGG Sep 9, 2013 06:27 PM
Thanks again. John
John,
That one is from JEPC (Jaguar Electronic Parts Catalogue) but I did have to do some cut&paste to get all the relevant info compressed into the single image.
motorcarman Sep 9, 2013 10:04 PM
2 Attachment(s)
The extra hose is for a modification to the crankcase breather system to keep the throttle clean. The throttles were 'sticking' so a bunch of mods were tried.
The new dipstick tube had a welded branch for the 'drain tube' from the vapor separator.
I installed DOZENS of these 'kits'. They are NLA by now.
Here is some info.
bob gauff
JC in VA Sep 10, 2013 11:01 AM
Thanks Bob. In fact my throttle sticks from time to time. And now is one of those times.
Brutal Sep 10, 2013 11:33 AM
Bob beat me too it, all should have them. Regardless of yr, but it was not a recall it was a customer complaint issue service bulletin. If no one complains and it doesnt happen you dont get it. They dont last forever, that valve seperates and leaks and yes no longer avail. But you can always make and should your own oil catch can :)
SleekJag12 Sep 11, 2013 05:01 AM
Thank you Tech Wizards, I hadnt seen that bulletin before. Its great to get the real story. My "Bro" and I (and probably many others) will be making oil catchers soon.
My kit equipped vehicle had the egr upgrade done some years ago. It has the decal by the left hood hinge. Perhaps the kit went in then.
© 2026 MH Sub I, LLC dba Internet Brands
