1998 XJR cruise
Hi all,
I was wondering how much work is involved in fitting cruise control to my 1998 xjr. Love the car but would love it even more with cruise! |
cruise
Your car didn't come with cruise ?
Hence the question re retrofitting.
I would start here:
http://www.jagrepair.com/images/Trai...ual-9-5-01.pdf section 5 has information about the cruse systems, components and diagram. hopefully you have most of the wires already run in the harness and just need to add the with/cruse components. |
Thanks mvirgil, that's a great document, will make a list of stuff needed and do some continuity checking, do you know if the cruise circuitry/programming is common to all ECMs or if I will need to get one from a cruise equipped XJR?
There's a 2001 xk8 being broken near where I live that has cruise control, would many of the components I need be the same on the xk?
I don't think the 2001 would work it has a aj27 and uses a completely different system. Your best bet would be a donor with a aj26 1998-1999 (early 2000?) here in the US. The best way to tell if the car has what your looking for is if there is a large black vacuum solenoid attached to the throttle body. Page 5.5 of the engine management manual has a good picture. I would assume XJR and XJ8 cruse systems would be the same for Aj26 equipped cars, but check part numbers to be sure.
