1999 xk8 lamp control module
Greetings gang!
I was having some problems with my rear tail lights on my 1999 XK8 (it was this way when I bought the car several weeks ago)...took out the 'lamp control' module (in trunk fuse box)...opened it up, and noticed several large resistors fried (along with the circuit board). I replaced 4 of the reisistors with the same value, hard-wired the burnt circut paths...plugged the module back in, and the tail lights worked perfectly for about 2 minutes, then back to the same problem as before. My 'gut' tells me that maybe a transister or two has actually fried before-hand??? Anyone out there on this forum have a salvaged lamp control module (or knows how to fix it)? The lamp-control module has the numbers= LJA 2245 AD / 05 8200 00 If so, please contact me at bowmanconsult@Gmail.com I sure would like to drive this cat at night. |
OOPS...I just realized this is in the wrong spot!
Sorry about that...I'll switch to the XK8 section.
