2001 XJR fault code please help
Hi I have just downloaded the following codes from my car I think it is the Lambda sensors that are at fault but if you can help that would be great. The car is running badly at tickover (misfiring) and lacks power ( it runs out of steam at about 135 mph were it should do 155mph)
P0300 P0301 P0302 P0303 P0304 P1316 P0420 P0430 P1000 P1113 P1647 If I am right and it is a Lambda sensor which one of the four is it. Thanks for your help.:icon_steer: |
Passed this a couple of times on my way down to XK8 section. Assuming your XJR will be the same DTC code set as my last 2001 XK8, here's the list:
P0300 = random misfire detected P0301 = misfire on A1 P0302 = misfire on A2 P0303 = misfire on A3 P0304 = misfire on A4 P1316 = misfire excess emission P0420 = catalyst efficiency below threshold on A bank P0430 = catalyst efficiency below threshold on B bank P1000 = drive cycle not completed since last code clear P1113 = IATS 2 sensor low voltage P1647 = ECM HO2S control malfunction B Bank upstream Good luck. Graham |
Another thing that could cause a single bank issue is if the exhaust cam chain had skipped a tooth due to a failing tensioner. That would screw up the O2 sensor readings and cause the MAFS/ECM to over compensate causing the B bank issue.
+1
Good point. Any doubts on tensioners and you need to be more worried about moving the next 135 feet than you do about investigating performance beyond 135 mph. Graham |
Thanks for that I know it is not the tensioners as it is a late model engine with the uprated tensioners, so any other ideas would be welcome, so I would be open to any other suggestions.
