2003 VDP sub-woofer R/R?
Guest
Posts: n/a
Hi,..new member here...hello all
...I just bough a 2003 VDP. All is good, but having cracking from sub-woofer in rear deck. Not much can be seen from inside the trunk,(boot)..looks like it has to come out from inside the vehicle..but..cant seem to figure it out without tearing up something(the vinyl covered rear tray cover)..any ideas on removing?..replace ?..any ideas greatly appreciated..
thanks....scrmbln
...I just bough a 2003 VDP. All is good, but having cracking from sub-woofer in rear deck. Not much can be seen from inside the trunk,(boot)..looks like it has to come out from inside the vehicle..but..cant seem to figure it out without tearing up something(the vinyl covered rear tray cover)..any ideas on removing?..replace ?..any ideas greatly appreciated..thanks....scrmbln
remove rear seats.. bottom first.. 1st remove rear underseat cover ( left andright)then there is access to remove 2 torxs that removes bottom cushion.. then once out .. there is about 4 torxs to remove back seat .. pull up and out.. with 2 people.. then parcel shelf is able to be lifted after removing some trim clips.. then replace sub.
Fletch44
Sep 28, 2015 02:21 PM
SoCalJagS
Sep 27, 2015 09:20 AM
