3100 mile road trip
just got back from a 3100 mile road trip through 14 states, car ran like a dream, in the southern states with flat roads I was getting 23.5 mpg at 75 to 80 mph. now comes my problem after a period of ten days my key fob and drivers window stopped working again,easy fix disconect negative battery cable and do a hardreset. then same thing a week later, if any one knows how to fix this problem permantly I would like to find out how.thanks in advance jrb53 I forgot to mention this is my 2000 xj8 (x308)
thanks....you give me confidence that i can/should be able to take a long trip and return with my xj8/long-2000-
as re the problem you are having...i don't think its that uncommon to get the window problem to come up again...after you do a cold/reset...the fob/remote problem may or may not be related. what i can say and after many posts on this issue is the absolute necessity of having a properly working battery. When was it last replaced?I would definitely have it checked out. I only mention this as the problem for me at least was resolved after i got a new battery last summer.good luck. |
Originally Posted by jrb53
(Post 904797)
JR...these cars are designed for the open road ;o)) I did a 10,400klm (6,400 mile) round trip to Western Australia and it purred like a big cat should....even one stint where i tested the cars top speed ;o) The car averaged 10.4klm/100klm which is 22.6mpg US and 27.16mpg UK As has been mentioned, how old is your battery? Have you replaced the batteries in your fob recently? After you do a hard set, did you re-set the parameters for your window? Open fully and hold switch for 3 seconds, fully close and hold switch for 3 seconds. Fully lock the car, wait 10 seconds and then unlock the car....this should fix it. I would definately have your main battery checked out....one thing these cars do not like is a dud battery. |
I do have a newish battery 6months old and new for the key fob. will do the window reset and lock as suggested thanks
