Battery Disconnect and Radio
Old 04-07-2008, 12:24 AM
dougs02's Avatar
Default Battery Disconnect and Radio
Will disconnecting the battery cause the radio to lose the code set? I can't find the radio code any where with the manuals or under the hood or trunk. The POs widow is senile and no help. I have changed batteries in a '95 XJ6 with no problems, Just don't know about my '02 XJ8. Is there a certain length of time the battery can be disconnected with losing the radio function?
Doug
Old 04-07-2008, 05:16 AM
Default RE: Battery Disconnect and Radio
The radio should be fine. If it doescome up saying code, pm me.
But should be set to US market, so no code.
Old 04-07-2008, 06:44 AM
what about canada? same thing? will it clear check engine light?
Old 04-07-2008, 01:49 PM
If there is a hard fault, likely will not clear engine light.
Old 04-08-2008, 08:50 PM
THANX FJT. DISCONNECTED BATTERY, ENGINE LIGHT GONE, RADIO FINE...EVEN PRESETS STILL THERE!
Malihide
04-02-2016 04:05 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
daniel06
XE ( X760 )
09-15-2015 07:07 AM
DuhCar
09-11-2015 10:58 AM
philwarner
09-02-2015 11:45 AM
Quick Reply: Battery Disconnect and Radio
