Air Suspension Fault
Old Feb 26, 2008 | 06:40 PM
DonsXJ8's Avatar
Default Air Suspension Fault
I've had my XJ8 for all of 3 days now and I have a "air suspension fault" and would like to know how I might go about reading/pulling the actual fault code. I might also
like to reset the code, if possible, to see if it was just a glitch or something I may mave done. I noticed the fault just after I pulled out of the driveway leaving work for home.
I had stared the car, after it had sat for 7-8hrs, and drove off. Could I have driven off too soon? I seem to remember reading that the suspesion might loose air while sitting but I
thought this was only ater several days or weeks. Anyway any help will be greatly appreciated. I have the Jaguar Select Warranty but I would just like as much information as possible before
I call the Dealer. Other than this I really love the car......
Old Feb 26, 2008 | 06:46 PM
jag_genius's Avatar
Default RE: Air Suspension Fault
it probably needs an air suspension pump.. or relay.. jag can only pull and delete code.. some times the pump does not pump enough within the first couple minutes.. setting a code..
Old Feb 26, 2008 | 06:57 PM
FactoryJaguarTech's Avatar
If it is a shock, get ready to pony up. Although available today, reman air shocks. $700 or so a piece. Better than $1000 for the new ones though. I think Select pays for compressor but not shock. But I am not 100% on the shock thing as it is not a regular shock.
Old Mar 14, 2008 | 02:36 AM
DonsXJ8's Avatar
Took the car by the dealer, turns out the problem was with a leaking valve block. They had the car for two days, provided me with a loaner, and fixed the car under the "select warranty" with nothing out of my pocket. All in all a pretty painless experience
Old Mar 14, 2008 | 05:30 AM
Good for you. Valve block is a rare problem.
Old Jul 25, 2011 | 10:53 AM
dbrown's Avatar
2005 XJ8L, relay for air suspension
Mugatu
22
Jun 23, 2020 01:50 PM
Forcedair1
Feb 19, 2020 01:51 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tonyforman
Sep 10, 2015 07:23 PM
philwarner
Sep 3, 2015 10:14 PM
