Bad Acceleration.
Old 04-04-2017, 09:15 PM
omgimali's Avatar
Default Bad Acceleration.
Past 3-4 days ago I've had to put my foot down more than usual. In that time period engine once stalled, and today the revs got low and i could hear the engine, but the engine saved itself. (new air filter, spark plugs, coil packs (2), hard reset, some fuel treatment (lucas, b-12), and everything checked up.
Old 04-04-2017, 09:50 PM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
MAF cleaned lately ?! Mine got erratic when it was gummed up.
The following 2 users liked this post by King Charles:
Don B (04-09-2017), omgimali (04-05-2017)
Old 04-05-2017, 05:02 PM
omgimali's Avatar
I cleaned the MAF December, Do you think it should be dirty in that short period of time? I also cleaned the TB then too.
Old 04-05-2017, 05:18 PM
I wouldn't think so, but it never hurts to check.
Old 04-05-2017, 07:57 PM
grandell's Avatar
Any other codes? Does sound like it might be the MAF if everything else has been checked.
When mine was on it's way out the car would hesitate under acceleration.
I cleaned it a few times, but the only fix was to actually replace it.
These are getting pretty old by now, so not entirely unexpected.
The following 2 users liked this post by grandell:
Don B (04-09-2017), omgimali (04-06-2017)
Old 04-06-2017, 12:50 AM
ericjansen's Avatar
Received 1,351 Likes on 926 Posts
In stead of witch hunting possible failing parts, any 'live' OBD readout will quickly give you a direction if it is air, fuel or spark related, and allows to check the functioning of quiet a few sensors.
Without it, it is more like a casino.
The following 2 users liked this post by ericjansen:
Old 04-06-2017, 01:24 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
check the sensors you understand (IAT, ECT,...) then fuel trims
The following 2 users liked this post by JagV8:
Old 04-06-2017, 03:00 AM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
Cleaned the TB? If it is one without the vacume acutator (black cylinder on the top) it is not allowed to be cleaned.
Old 04-06-2017, 03:16 AM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
XJR? Maybe you're down one fuel pump.
The following 2 users liked this post by plums:
Old 04-06-2017, 03:27 AM
Stu 1986's Avatar
Are your battery connections tight? Are all the grounds tight? A loose connection could cause symptoms like you describe.
The following 2 users liked this post by Stu 1986:
Old 04-06-2017, 02:52 PM
omgimali's Avatar
naturally aspirated v8 - 1 pump.
I ordered a OBD-II blutooth for my phone yesterday and got 2 day shipping It is going to be here tomorrow.
Don B (04-09-2017)
Old 04-06-2017, 06:46 PM
ericjansen's Avatar
Good move.
You should be able to read and check the values, and see life progress of several main components and processes.
As a start, concentrate on the MAF and intake temp for air, the throttle position and short + long term fuel trims, the timing advance for spark, and the coolant temp.
One of those will probably be out of spec, which you can then hunt further.
Don B (04-09-2017), omgimali (04-07-2017)
Old 04-07-2017, 03:19 PM
omgimali's Avatar
what should be the readings?
Old 04-07-2017, 05:26 PM
ericjansen's Avatar
MAF:
See attachment (for N/A)
Intake temp for air:
Ambient temp when startup, somewhere halfway between ambient and engine temp when stopped, lowering when riding again
Throttle position:
Between ~1% untouched, warm engine, till 90% full throttle
Short term fuel trims:
Depending engine load between -10 till +10, limit is some -15 till +15
Should come back close to zero when normal highway use
Should read zero when coasting
Left and right bank should be close to same
Long term fuel trims:
Should read within some -3 till +3, no more of -5 till +5 on a healthy engine
Timing advance:
Need to check
Coolant temp.
Ambient temp when startup, some 90-95C on normal use, bit higher if load increases
The following 4 users liked this post by ericjansen:
Don B (04-09-2017), JagV8 (04-08-2017), Jhartz (04-09-2017), omgimali (04-08-2017)
Old 04-08-2017, 01:56 PM
omgimali's Avatar
Thanks for the information Eric appricate it.
Ok so here are the results all during idle.
STFT1- 0.8 - 1.6
Intake Temp - 38.0
Engine Coolant - 95.0
Engine Load - 15.7
MAF - 4.7
Intake Manifold - 21.3
Throttle - 0.8
Timing Adv - 4.5
Boost - 6.5 (vacuum i believe)
Old 04-08-2017, 01:59 PM
omgimali's Avatar
All was done at temp
Old 04-08-2017, 05:22 PM
ericjansen's Avatar
I miss your Long term fuel trim, but guess that one is OK with such STFT.
Now you will get to check your MAF at the other conditions, and then just go driving and monitor whats going on, and see if you can figure out anything before or during the 'bad acceleration'.
Which program you use on your smartphone?
Old 04-08-2017, 05:38 PM
omgimali's Avatar
I tried my iphone but the good apps start at $15. I used my dads Galaxy s7 and the torque lite app.
Old 04-08-2017, 06:57 PM
ericjansen's Avatar
Ok, if you choose a ''half-dial'' in Torque, you will get a gauge which also records the lowest and highest reading.
This is helpful to initially scan values, while still keep an eye on the road.
Don B (04-09-2017), omgimali (04-08-2017)
Old 04-08-2017, 08:01 PM
omgimali's Avatar
Ok while driving what should I be looking for?
