cable passage
hi to all I ask information for mounting subwoofer under seat from the battery where I find the passage for the cables to arrive under the front seats? there are two subwoofers, I thought I would come with the audio cables to the car radio passing next to you what do you say?
Since your trying to put them under the seat, you'll need to pull the seat out to run the cables. The wiring should run under the carpet. I plan to run through the center council and coming down through where the armrest insert is to bring my wiring in for my bass. This is what I'm going to use... ...scroll down to the images provided by others who have bought them. Mine are going into the back rest.
I'm mounting two ultra flat subwoofers to put under the front seats with 200Watt Rms each from the battery where can I switch with a cable to power the divers?
I hope you have enough room under the seat for that? As for power, are you coming off the head unit or an amp? I'm unfamiliar with powering these direct.
I remembered this old thread... https://www.jaguarforums.com/forum/x...estions-87190/ ...perhaps there's something there to assist you? |
https://macrom.it/it/car-audio/audio...icati/m-sw1000 these are the sub and they are already amplified by the battery I have to get to them where I pass? with the measurements it seems to be ok
I hope they fit, ...if your going to come directly off the batter then, you can take out the back seat and go under the carpet from there. There's a gap beside the backrest to get wire through.
https://cimg2.ibsrv.net/gimg/www.jag...d8a1b99716.jpg This is an old post pic I was telling someone else the same thing a few years ago. |
