Cat, O2 sensor cleaner recomendations?
I have seen several products for putting in the fuel tank that clean the cats and O2 sensors, any recommendations as to which is the best? Mr. Gasket, Solder One, etc??
I don't think any of them work, it's snake oil.
Since you'll probably be diving into this endeavor.... https://www.jaguarforums.com/forum/x...cement-195018/
Excellent! Thanks man |
After reading over the tutorial you supplied, I see the codes are different than what my car is throwing. Mine are P0171 and P0174...lean left and right banks...? |
Originally Posted by 3timejag
(Post 2039476)
P0171 and P0174...lean left and right banks...? The generic code list states:
Engine misfire Air intake leak between MAFS and throttle Fuel filter, system blockage Fuel injector blockage Fuel pressure regulator failure (low fuel pressure) Low fuel pump output HO2S harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECTS, MAFS, IATS, TPS |
That makes sense. When my mechanic replaced the plastic thermostat housing with an aluminum one a while back, he accidentally broke the little hose coupling that goes into the engine close to that area. He “fixed” it with some silicone, or something like that, I’ll bet that has failed. Make sense? |
(Post 2039507)
Bingo! Lifted the left engine cover, and there it was...broken full load breather hose! Repaired it, and all is good. Thanks for “reminding “ me of that previous repair... Still have a P1000 code I can’t figure out though. Many thanks to all for the help and replies! Scott |
The P1000 was not likely to change to P1111 with a fault like that but now has a chance.
