Changing transmission fluid
I just had a shock when pricing Jaguar A/T fluid for our '03 XJR. Parts man admitted it was unreasonably high and suggested looking at Redline.
The recommended Redline fluid is D4 ATF......is anyone familiar with this? I can buy enough for the complete change for roughly the price of one quart from Jaguar. Also, can anyone give me a location to buy appropriate oil for the SC? Thanks in advance for any help offered. |
Edit :
Disregard I misread your needs. |
You have the W5A580 (AKA 5G Tronic, 722.6) Mercedes Gearbox.
Use the recommended Mercedes fluid. It is not hard to find and is not THAT pricey. bob |
I’ve used this kit on my last 2 XJRs for servicing the supercharger.
https://www.ebay.com/itm/Two-GM-Supe...UAAOSwSMZbcfti Bob is right, the MB fluid is not expensive, relatively speaking... cheaper than if you had a ZF transmission. For what it’s worth though, I used the following in mine about a year ago. https://www.ebay.com/itm/12-Liters-F...item56ae5432b3 |
