Chunk/Thunk Sound in Rear Pass Side
Old Sep 26, 2019 | 03:13 PM
Len Apcar's Avatar
Default Chunk/Thunk Sound in Rear Pass Side
Every time I go over a bump, seam, small wrinkle in the road I am hearing a new thunk-chunk sound in the rear. Put it on a lift, pulled all wheels and there are no mechanical or structural issues -- no wear or malfunction in brakes, pads, rotors, springs or shocks. Trunk/Boot clear. Battery secure.
Ideas?
Thanks.
Old Sep 26, 2019 | 03:31 PM
Jhartz's Avatar
Check the rubber donut that holds the exhaust system stable. It will be in the back before the bumper.
Old Sep 26, 2019 | 04:28 PM
willie/billy's Avatar
Default Hi I have a 07 jag xtype diesel 2.0
I have the same problem near side rear bump thump exactly as you describe had it up on lift mechanic went round all joints with jemmy bar all joints bushings exhaust everything we could prise or stress still nothing we are going to try some the underseal pls any help would be appreciated as I have a 300 mile journey in a few weeks
willybilly
Ideas?
Thanks.
Old Sep 26, 2019 | 06:28 PM
King Charles's Avatar
After battling this recently, I can tell you there's numerous things to check. Suspension donuts,shocks,exhaust hangers,drive line bushings/bearings(hub & differential),universal joints.
Old Sep 26, 2019 | 06:59 PM
Highhorse's Avatar
Check the A frame truss mount bushings just in front of the rear wheel wells also. If either of the points on either side have been used to jack up or support the car, if they were bent, they will cause a thump also.
Old Sep 26, 2019 | 08:04 PM
motorcarman's Avatar
The rear spring isolators and damper bushes are a foam that deteriorates!!!!!!!!!!!!
My bet is the rear damper mounts.
bob
Old Sep 28, 2019 | 07:52 AM
VivaJag's Avatar
Had similar experiences. Turned out small pebbles from my driveway stuckstuck in the tires that were launched into the wheel cap. Horrifying sound.
Old Sep 30, 2019 | 05:02 PM
Tks for interest have alloys so no problem there
Old Oct 6, 2019 | 10:33 PM
Len Apcar's Avatar
thanks. let me know if you kind the culprit!
Old Oct 6, 2019 | 10:35 PM
Len Apcar's Avatar
Thanks, King Charles. Do you remember what took care of the noise? Mine is getting more thunky!
Old Oct 6, 2019 | 10:41 PM
Mine was the roller bearing driver side rear, #15 in diagram. It presented as a knock then creak under load.
Len Apcar's Avatar
Thanks, Motorcarman! I have followed your advice for years especially because you are not far from my wife's home town, Wichita Falls.
Are there parts to replace the foam rear damper bushings? Is there a better substitute than foam? I dont yet know if that is the problem, but it would a good place to start and I'd like to know what the part choices are.
Thanks!
Old Oct 7, 2019 | 09:10 AM
I buy the damper top isolators from my local Jaguar dealer and I get the spring isolators from RockAuto. (the spring isolators are less than $30)
The lower damper bushes (SPHERICAL JOINTS) are available as well. They sometimes make a 'thunking' noise so look at those.
bob
Old Oct 7, 2019 | 04:52 PM
Fraser Mitchell's Avatar
Is the rear subframe similar to the previous car ? It was a regular job with these to replace the "A-frame" subframe bushes.
https://www.jaguarforums.com/forum/x...shings-132485/
Old Jan 20, 2020 | 11:11 PM
Len Apcar's Avatar
Everyone, We found the culprits causing the thunk/chunk sound in the rear. Motorcarman was correct! Congratulations. It was the big donut foam bushings as he described, and the worn insulators and bushings at the rear shocks. The only way to replace the shock insulators and bushings was to replace the main shock set up, which we did. They were 10 years and 50,000 miles old. But the big donuts bushings were probably the main cause of the noise.
Thank you all for your help.
jvegas
Apr 3, 2015 08:03 AM
quaker13
Mar 26, 2013 10:09 AM
Simprof
Jun 25, 2012 08:48 AM
Mistahchin
Aug 7, 2010 09:49 PM
nthegrip
Sep 13, 2009 10:30 PM
