Steel wheels for snow tires
Old 10-14-2011, 03:34 PM
lcotelaw's Avatar
Default Steel wheels for snow tires
I am looking to purchase 4 plain steel rims to mount my winter snow tires on - 1999 VDP. Can anyone recommend a reliable source? Nothing fancy is necessary.
Larry
Old 10-14-2011, 04:15 PM
Sinister 1's Avatar
It might be easier to get a set of 16" wheels from a car that is being dismantled. That's what I did.
Otherwise steel wheels from a 1980's Chevrolet S10 or Camaro might fit. The bolt pattern is the same and the offset is close. Not sure about the center bore though.
Old 10-17-2011, 03:45 PM
lcotelaw's Avatar
Thanks for the idea. I have been looking for a salvage source as well as new. As for what fits, I found the technical data and a cross reference chart, soI have that angle covered. I just need a source for either used or new steel rims. Thanks again
Larry
Old 10-18-2011, 01:48 AM
yeldogt's Avatar
I use a set from a late 90's XK8 for my winter tires on my XJR Bought them for my x300VDP as summers and used the original VDP's 16's for my winters.
A lot of rims will fit -- I'm surprised you are having a problem finding a set?
Old 10-18-2011, 03:28 AM
Stu 1986's Avatar
This is common practice in Germany, you see a lot of top end BMWs and Mercedes running round on steel wheels or ones with wheel trims in the winter.
Old 10-18-2011, 04:25 AM
SimoCat's Avatar
What's recommended for an STR?
Old 10-18-2011, 01:12 PM
lcotelaw's Avatar
SimoCat: What does STR stand for?
Old 10-18-2011, 06:38 PM
Stu 1986's Avatar
They are my initials! But in the world of Jaguar it stands for: S-Type R. Like an XJR but in an S-Type body.
H20boy
07-23-2021 09:39 PM
smith356
10-07-2015 06:41 PM
Armor6
09-14-2015 07:56 PM
Armor6
09-10-2015 12:08 PM
1964Daimler
09-09-2015 11:28 AM
Quick Reply: Steel wheels for snow tires
