Coolant hose under supercharger
https://cimg9.ibsrv.net/gimg/www.jag...95a275659.jpeg Has anyone replaced the hose that goes down the center under the manifold? It looks as though the supercharger has to be removed? |
There's only 20 or 30 threads on it, done in quite detail also, there's 2 lines. Do a search for supercharger coolant lines x308.....and yes, the SC has to come off.
As per HH a search will reveal info on this, I think this is one may be one of the most informative.....................
https://www.jaguarforums.com/forum/x...harger-152089/ |
I’ve basically decided since it’s a 2-3 hour job pulling the s/c I’m doing everything that can be done. Valve cover gaskets, knock sensors, new pulley, rebuild the snout, have the s/c checked for clearances and rebuilt if needed, all hoses, and since I already removed the throttle body I’m gonna strip it down and thoroughly clean it too. |
That is usually the route most folks take when accomplishing this task. Be sure to clean up the hose connection ends you don't replace (trim off the stretched ends) and you'll find better performance there also.
Originally Posted by tahoemedic
(Post 2018445)
I’ve basically decided since it’s a 2-3 hour job pulling the s/c I’m doing everything that can be done. Valve cover gaskets, knock sensors, new pulley, rebuild the snout, have the s/c checked for clearances and rebuilt if needed, all hoses, and since I already removed the throttle body I’m gonna strip it down and thoroughly clean it too. Not sure what your plan is for the supercharger, but I would at least change the oil, and coupler (use a new OEM coupler). |
(Post 2018445)
Replace the part load breather tube while you’re under the SC. It will be extremely brittle and will probably crumble when you touch it, but it is plumbed to the intake elbow under the throttle body, and you will have a massive vacuum leak if you don’t replace it, even if it looks ok. It happened to me. In my case, I was able to replace it later because the line does not HAVE to run under the SC, but life would have been simpler had I just replaced it while I had the SC out. Also clean out the port where the part load breather tube goes into the engine in front, using a small drill bit, held in your hand. Do not drop the drill bit in the engine! I clipped a small vice grip on the drill bit to be safe. Might as well change the SC oil while you have it out. |
One other thing you might want to consider. Brass insert on side of TB elbow. C2S15816 You won’t need to replace the brass itself but, the o ring inside along with the plastic retaining clip most definitely will need replaced. |
