Cooling problem?
Hi. Over the past month or so I've noticed that my cooling fan comes on for about 30 seconds almost every time I turn off the motor. It also happens occassionally while idling. I don't recall this happening last season and the weather in Southeast PA as not been that warm.
I do get heat in the cabin and the temp guageshows no problem. I have not changed coolant in the 2 years I have owned the car and have not needed to add much.Is there something I should check? Thanks '01 XJR |
#1 Guess is thermostst.
The Temp Gauge will not show any deviation until a Real Problem exists. BAD ?? Yes, for guys like us. Several things could be wrong, but, I would switch the thermostst, which is a 30 min job.
RE: #1 Guess is thermostst.
your guess was right on! Replaced thermostat and no more fans after shut down.
Thanks |
As a point of insurance it may be an idea to change the water pump - this can wear quite quickly as they are plastic inside and have a tendency to break up - if the engine is does start to over heat because of a faulty pump it will do so very quickly and then you could be into big money. A new pump should cost about 100 $ +/-.
Hope it's ok. Cheers G. |
rickpa
put a thermostat in it verry common issue PM me and i"ll send you pic of the new and old style water pumps if you have new stlyle disregard replacing it hope this helps |
