Cylinder C ignition coil problem
Old May 17, 2026 | 11:23 AM
jaytee1000's Avatar
Default Cylinder C ignition coil problem
Hello, my friend has a 2003 xj8 (American drivers side) and I’m helping him try and diagnose and fix an issue (we don’t know the most about cars but we are learning). About a month ago it would start to go into rough idle and limp mode. And it read P0303. We looked it up and replaced the 3rd ignition coil (from what we could find online it was the 2nd one from the front on the left). The issue still persisted after this. We check again and the same error code. We are thinking it might be an electrical issue now and we are going to have to replace the connector. We just wanted some more informed opinions on what we should do.
Old May 17, 2026 | 11:31 AM
motorcarman's Avatar
Wrong coil.
This pic has been displayed on this forum for years.
See the actual coil/cylinder layout for the 4.0
Old May 18, 2026 | 02:10 PM
Jhartz's Avatar
Another example of confusing Jag docs: on the X308s, 303 is third back on right side -- as Bob noted. I guess the confusion rests with the fact that in the UK, 2003 models are 350s.
Old May 18, 2026 | 10:46 PM
Vauxi's Avatar
X350 in uk started at 2003.5. In usa 2004.
mjmindling
May 11, 2026 07:51 AM
Ilovejags
Feb 25, 2026 05:23 PM
Deanrobert
E type ( XK-E )
May 28, 2023 12:37 AM
graham11
Mar 25, 2020 11:42 AM
loblue
Aug 17, 2011 07:00 AM
