Daimler Jaguar XJ8
Old Aug 17, 2016 | 12:17 PM
allanacg's Avatar
Default Daimler Jaguar XJ8
warning light comes on saying gearbox fault but analyser says faulty alternator
_________________
V8 Daimler 2001 LWB (added by GGG)
Old Aug 17, 2016 | 01:26 PM
Welcome to the forum allanacg,
There's some unusual products come out of Jaguar Special Vehicles but I've never seen an XK8 badged as a Daimler.
Either the code reader is giving you false information or you aren't using the Jaguar DTC tables to interpret the codes. What are the actual error codes?
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Aug 17, 2016 | 02:25 PM
allanacg's Avatar
Default Daimler Jaguar 8 2001
should read V8 no XK8 WHICH IS OUR OTHER CAR
Old Aug 18, 2016 | 04:17 AM
So is this problem with the V8 (X308) or the XK8 (X100)?
Old Aug 18, 2016 | 07:52 AM
allanacg's Avatar
the four litre V8 Daimler 2001 LWB
Old Aug 18, 2016 | 09:17 AM
I've moved your question from XK8/XKR to X308 forum and edited the thread title from XK8 to XJ8.
Members here with the same model will be able to help.
Old Aug 18, 2016 | 01:31 PM
avern1's Avatar
First post the code from the reader as it is. The interpretation of codes by the reader are usually wrong for Jaguars. The code numbers are Jaguar specific and not generic. Second Clear the code and the clean the battery connections. ground strap connections and have the battery tested. Weak batteries and bad power connections throw all types of weird code numbers.
Old Aug 20, 2016 | 12:27 PM
vdpnyc's Avatar
If you get a code for throttle body positioning sensor (fairly common, happened to me, and car says "gearbox fault" when it happens even though nothing to do with transmission) you'll need to swap the entire throttle body unit ($1k usd for rebuilt unit)
silversurfer1221
27
Sep 27, 2022 02:06 PM
klfong
33
May 18, 2022 11:25 AM
99jagVDP
Apr 2, 2022 01:39 PM
silversurfer1221
Apr 5, 2016 09:46 AM
silversurfer1221
Mar 31, 2016 08:33 AM
