Does your VDP have shorter door trim on one side?
Those are pretty easy to take off. With the door open use a wedge shaped tool that wont scratch the paint (not a screwdriver) and wedge it between the top of the door skin and the trim piece. Gently pry the trim piece upward until you can get your fingers under it and pull it up the rest of the way.
Installing the new one is easiest if you start with the trim tipped down at the front and locate it using the glass and forward edge of the door as a reference. Push the front end down to seat the clip and then tip the rear edge down and seat the clips as you go.
If you buy a used part make sure to ask if there is evidence of corrosion on the back side of the weatherstrip. They are prone to having that issue and if you get a rotten one to start with you'll be buying another one soon.
If you buy a new one let us know what it costs. I know mine will need replacing in a year or so.
Ken
Ken
99xk8guy
06-05-2023 06:28 AM
Wolfy
04-06-2019 10:40 PM
Dicque
09-19-2015 12:53 PM
