Dimensions of X308 XJR intercooler radiator
Without buying a used X308 XJR intercooler radiator first, I'm trying to determine if the intercooler radiator on the X308 XJR is larger than the intercooler radiator on the X300 XJR6.
Does anyone have an X308 XJR intercooler radiator lying around that you could measure the overall width, height, and thickness and post? |
560 mm wide (excluding the mounting ears and hose ports), 310 mm tall (~320 mm measured along the side flanges). The core is 32 mm thick and the thickness measured at the side flanges is 50 mm.
Thanks,just what I needed! :icon_beerchug:
