Door Speaker Replacement 6.5" to coaxials?
2000 XJ8 has broken speaker grills in the front (previous owner found speaker grills a convenient location to push door open with feet) and the front speakers buzz when strong bass is played. I want to swap out all 4 of the 6.5" door speakers. Can I simply replace with coaxials? I am aware there is funky connector which I can cut off and replace with standard connectors. Is that possible or is the wiring from the amplifier going to give me a problem? If you haven't noticed, I am an audio novice.
I understand door panels need to come off and thankfully I know how to do that. |
I just repair the foam surrounds on all my speakers.
https://www.simplyspeakers.com/speak...e-it-kits.html https://www.speakerworks.com/speaker..._kits_s/65.htm bob |
That's a good fix Bob suggested, and works perfectly on the premium subwoofer, which is a hard item to replace as they're shallow and dual voice coil speakers.
Any quality speakers will fit, but rather than cut the loom connectors, you can solder the connectors off the old speakers onto the new for a factory look and install. |
I prefer to replace the speakers and the broken grills rather than repair them. My issue is the door molding has a fixed diameter which really can't be modified since it is a molded fit. See photo.
I haven't taken the door panel off yet but it appears that the grill mounts from behind the panel. If I can purchase a new grill that fits exactly in the opening then I assume that I can put most any speaker behind it. True? https://cimg4.ibsrv.net/gimg/www.jag...db34620d06.jpg |
https://www.jaguarforums.com/forum/x...anyone-190969/
I went /w Rockford Fosgate P165 6.5" 2-ways in my doors, sound awesome & fit perfectly. Practically a steal nowadays, if you can find them. |
My memory is of a typical design -- the ring and grill are part of the panel. The speaker is attached to the door.
Used yards often want to sell the whole panel -- but you may find someone with just the grills. Slapping a speaker through the panel and into the door is not going to look very good. It's more often the case that OEM audio is specifically designed to be difficult to modify -- strange speaker size w/odd ohm etc. But if KC above had good luck with RF's .... that may be the way to go. Fixing is an easy way to go. |
Originally Posted by AltonJag
(Post 1864571)
I haven't taken the door panel off yet but it appears that the grill mounts from behind the panel. If I can purchase a new grill that fits exactly in the opening then I assume that I can put most any speaker behind it. True? https://cimg4.ibsrv.net/gimg/www.jag...db34620d06.jpg My 2001 came with the standard audio system and I replaced the speakers with 6 3/4" Pioneer mid-base model 1720's and Clarion tweeters. The difference in sound quality was amazing but the bass response suffered. The Pioneer's weren't designed for the poor enclosure of the 308's design. But from 200 hz on up the change was more than worth it. Very smooth mid-range and crisp highs. Really needs a subwoofer though. I also replaced the standard head unit with an aftermarket Alpine. Most websites list the speaker size as 5 1/4" but they are really 6 1/2 - 6 3/4". I also believe (but not sure) the woofer gets a full range signal so you might get an increase in treble response from a coaxial speaker. https://cimg0.ibsrv.net/gimg/www.jag...0ac0d25164.jpg |
Thanks everyone, I installed 6 1/2 inch Rockford Fosgate 3 ways today. Sound great. 18 year old paper one ways were shot.
I'm thinking about replacing the door speakers on my 1999 XJ8 with basic sound system, tweeters in door handle cups, no sub woofer in back and was wondering if these would work in stock locations:
Also wondering if I would need an amp to go with them and if so where would it be placed in the system. Just saw these and wondering if they might work better by just unplugging existing tweeters since they are full range: Anyway, your advice and comments and appreciated. |
I simply replaced the stock 6" one-way speakers in all 4 doors with 6" Rockford Fosgate 3 ways and kept the stock tweeters and rear subwoofer connected. The stock tweeters and subwoofer are probably inferior since they are 18 years old but I didn't test the sound by disconnecting them. My teenage son drives the car and he's not complaining, so far.
Thank you for the reply, I don't have the system with a subwoofer and wondering if the stock head unit will have enough power to drive the four replacement door speakers if I go with the three way RF.
It will be fine. But 3-ways are probably a waste of time. 6" 3-way speakers are usually more of a gimmick, and you might be better off getting a higher end set of two way coax's
You should be ok leaving the factory tweeters in place too, but if it sounds a bit too 'bright' then you can drop the treble at the headunit, or maybe cut the wires to the tweeter in the new coax's |
Thank you for the response, could you recommend a higher end two way that would do well without a subwoofer in the rear and powered by stock head unit.
I'm looking at replacing both front and rear door speakers. |
I can recommend a lot of very expensive speakers... but it's all dependant on your budget.
If you stick to reputable shops and brands you can't go too wrong. Look for something with a higher sensitivity, rather than something with a high power rating, as these will play better on your factory headunit. |
I ended up ordering four Rockford Fosgate P1650 2 way full range speakers and a Rockford Fosgate R300 50 Watts x 4 Amp to go with them. They should be here by mid next week and after install I will post results.
Please do. I most likely will do Alpine R's all around, with their mrv 4 channel amp.
Sure will and something else to consider, I originally ordered a cheap 17.00 Boss installation kit but after researching further cancelled and went with a 60.00 Rockford Fosgate kit with very good reviews. The cheap kit had a history of catching on fire and poor performance so something like that is well worth looking into.
Originally Posted by astark
(Post 1917615)
Copy of the CAC Good, Bad, and Ugly List - ecoustics.com |
Thanks for posting that list, very informative and appreciated.
Had the Rockford Fosgate P1650 2 way full range speakers and a Rockford Fosgate R300 50 Watts x 4 Amp professionally installed and wow !! this setup sounds great. The amp came with a factory measured 402 watts RMS and its running at about 50% to the speakers producing very crisp highs, nice deep lows with a little thump, excellent mid range and I'm very impressed. Everything from Steve Rothery The Ghosts of Pripyat to Jethro Tull Aqualung sounds incredible, Dave Mathews with Tim Reynolds and anything else I have plugged into the stock CD player as well. The stock speaker grills were maintained and all wires are hidden, so you can’t tell any difference from the stock base system until you turn it on, and then wow !! this setup sounds great.
