Drivers door does not stay open.
Old Dec 25, 2022 | 12:02 PM
asjdhsajhdfj's Avatar
Default Drivers door does not stay open.
Hi,
I’ve taken a picture of the supposed mechanism that’s linked to holding the door at a desired position.
Is something missing?
Old Dec 25, 2022 | 04:42 PM
xalty's Avatar
the door
Old Dec 25, 2022 | 07:39 PM
asdf's Avatar
Unfortunately, your door check arm broke and the metal it was bolted into got ripped out. It's a relatively common issue. Good news is that you can get a new check arm on ebay for around $50. You'll need to straighten out the metal in the door and then use wide washers in order to distribute the load on the faulty metal. Yours is so buggered that I recommend installing thin steel plate on each side instead of washers. When mine was broken I just took the piece out altogether for a couple of years before fixing it. So if you're short on time, you can just do that.
I believe there was previously a write up with pictures on this subject, so if check the stickies. If you have any more questions, ask away.
Old Dec 25, 2022 | 07:44 PM
asdf's Avatar
Ah, found the write up: https://www.jaguarforums.com/forum/x...art-how-36075/
olivermarks
Jan 28, 2023 10:54 PM
05strSATX
Jul 7, 2021 01:08 PM
pcolapacker
Jun 29, 2021 09:42 PM
Kevinuk1
May 7, 2018 06:16 PM
